Okuma
Compact Multitasking Machine Improves Process Integration
PMTS 2017: The Speedio M140X2 compact multitasking machine, from Yamazen Inc., integrates turning and milling processes, contributing to high efficiency machining to save both time and money.
The Speedio M140X2 compact multitasking machine, from Yamazen Inc., integrates turning and milling processes, contributing to high efficiency machining to save both time and money. The machine has recently been enhanced to allow more flexibility for jig design and improved machining capabilities, including more advanced complex machining work.
According to the company, the machine brings a reduction of handling time by performing both turning and milling, therefore eliminating the additional setup. Also, because multiple processes can be performed through a single chucking, workpiece attachment errors are eliminated and machine accuracy is improved.
  • Watchmaking: A Machinist’s View
  • When Organic Growth in Your Machine Shop Isn’t Enough
  • When Too Many Customers Spoil the Part
    Duo CNC used to take on as many customers as the shop could handle. But when growth stalled, a top-down audit by the company’s general manager revealed that its customer base was inhibiting growth — and causing the shop to be less efficient and productive.
Okuma
High Accuracy Linear Encoders
MMS Top Shops
Okuma
