Compact Tool Setter Speeds, Simplifies Setup
Marposs Corp. will introduce its Mida TS30-90 tool setter for machining centers, which features an integrated interface incorporated within its compact body that is designed to speed and simplify setup on the machine tool.
Marposs Corp. will introduce its Mida TS30-90 tool setter for machining centers, which features an integrated interface incorporated within its compact body that is designed to speed and simplify setup on the machine tool. The 90-degree tool setter also features a streamlined system for fast and easy alignment.
The tool setter can be used for a variety of applications, including measuring tool length with stationary or rotating tools, tool radius and individual flutes for inspecting indexable inserts, as well as monitoring tool wear and tool breakage.
When to Use Custom Macros With a CAM System
Custom macros can offer benefits even when using a CAM system to prepare programs – but must be implemented with the right considerations.
Swiss-Type Control Uses CNC Data to Improve Efficiency
Advanced controls for Swiss-type CNC lathes uses machine data to prevent tool collisions, saving setup time and scrap costs.
