The Ideal 320 is a competitively priced 12-ft. bar feeder for Swiss- or fixed-headstock-style lathes. The unit features calibrated hydrodynamic round-section guide channels and mechanical headstock synchronization. It is designed for applications ranging in diameter from 0.118" to 0.787" (3 to 20 mm) and has a front “outboard” bushing device that enables adjustment to all diameters without the need to change bushings, provides adjustable steady-rest support and helps reduce vibrations.
