Complete Machining Products
Horn’s System DR Reaming system features narrow cutter inserts for precision machining of steels, cast materials, non-ferrous metals and plastics. The DR product, produced under license from Urma AG, is available with cutting edge diameters ranging from 0.465" to 5.518" (11.9 - 141 mm).
New Product From: 7/2/2010 Modern Machine Shop
Horn’s System DR Reaming system features narrow cutter inserts for precision machining of steels, cast materials, non-ferrous metals and plastics. The DR product, produced under license from Urma AG, is available with cutting edge diameters ranging from 0.465" to 5.518" (11.9 - 141 mm). The inserts are available in both coated and non-coated carbide, as well as cermets. All diameter cutters are available with straight flutes, or left-hand helical flute geometries for reaming both through-holes and blind holes. Four cutting geometries are available for the straight-flute versions and two for the left-hand, helical-flute version. The inserts can be exchanged by a positioning pin and torque specific screws.
The insert holders are available as cylindrical shanks, with internal coolant supply (through the tool) in both short and long versions for diameters ranging from 0.468" to 1.401" (11.9 to 35.6 mm). Two variations are available, the IKD for through-holes, and IKS for blind holes. Insert holders for diameters ranging from
1.401" to 5.518" (35.6 to 141 mm) have their own mechanism for reducing runout alignment.
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
HORN USA Inc.
MMS Zones
HORN USA Inc.
Zones
Supplier Categories
