Coolant Cleaners Maximize Cutting Tool Life
Eriez’s HydroFlow permanent magnetic and rare earth coolant cleaners are designed for use with surface grinders, gear grinders, honing and lapping machines, milling and drilling machines, and other equipment requiring clean coolant.
Eriez’s HydroFlow permanent magnetic and rare earth coolant cleaners are designed for use with surface grinders, gear grinders, honing and lapping machines, milling and drilling machines, and other equipment requiring clean coolant. The cleaners are said to maximize the life of cutting tools, grinding wheels, pumps and coolant fluids. Radial-design magnetic circuits extract ferrous particles to help meet tolerances and improve surface finish in grinding and metalcutting operations. According to the company, the cleaners are easy to install in restricted spaces, and can be used on new or existing machines. Various models and capacities are available.
Oelheld Coolant Increases Metal Removal Rates
The odorless coolant is said to offer increased removal rates, lower electrode wear, excellent surface qualities, lower refill quantities and longevity to provide lower overall operating costs.
Ultra-fine Filtration of Cooling Lubricants
Vomat filters act as an important, value-adding factor in metalworking.
168 Manufacturing's Coolant System Automates Delivery
PMTS 2023: FullShop systems monitor and replenish all CNC machine sumps with optimized top-off ratios before the coolant runs low.
