Coolant Recycling System Reduces Waste
PRAB’s Guardian coolant recycling system is said to reduce fluid purchases by as much as 75 percent and reduce waste fluids by as much as 90 percent.
PRAB’s Guardian coolant recycling system is said to reduce fluid purchases by as much as 75 percent and reduce waste fluids by as much as 90 percent. According to the company, free-floating and mechanically dispersed tramp oils are reduced to 0.1 percent or less at process rates ranging from 90 to 1,500 gph. Larger capacity units are also available. The system operates on a continuous overflow process with multiple passes to prevent rancidity. An automatic air sparger purges coalescing media of solids and sludge. An optional polishing filter enables tighter coolant clarity tolerances. The fluid reclamation system is suitable for operations with industrial coolant or washwater reserves.
AFT's Semi-Synthetic Coolant Extends Sump Life
Advanced Cool 2200 provides high visibility while machining, keeping the machine and parts clean with no odor issues.
Hennig Inc. Acquires Industrial Coolant Systems
ICS develops and field tests high-pressure coolant systems, coolant filtration systems and other machine tool solutions.
Master Fluid Solutions Semisynthetic Coolant Inhibits Corrosion
Trim MicroSol 685XT is designed to provide enhanced corrosion inhibition on all ferrous and nonferrous metals.
