Custom Tooling, Support Offered
YG-1 offers a range of special and made-to-print high-performance tooling including end mills, drills, reamers and routers.
YG-1 offers a range of special and made-to-print high-performance tooling including end mills, drills, reamers and routers. Tools made of solid carbide, high speed steel, cobalt and powdered metal are available. The company provides support from tool concept and creation to testing, training and implementation via its Charlotte, North Carolina, U.S. Tech Center. Other services include modifying existing products, reconditioning used products and developing complete tooling programs.
