Deep Hole Drilling Machine Features Automatic Loading
Mollart Engineering’s LD4 Drillsprint deep hole drilling machine features a 750-mm stroke and fully automatic loading and unloading.
New Product From: 8/8/2012 Modern Machine Shop
Mollart Engineering’s LD4 Drillsprint deep hole drilling machine features a 750-mm stroke and fully automatic loading and unloading. The machine’s capacity ranges from 2 to 16 mm in diameter by 750 mm deep. It can be supplied with counter rotation to create concentric bores and is well-suited for thin-wall components, the company says. A range of automation solutions are available, including gantry, pick-and-place and robotic systems. Machines can be supplied with one, two, three or four spindles.
The Type 113-hp, single lip, solid carbide Botek gundrill will also be on display. Tools are available between 0.7 and 12 mm in diameter with a depth-to-diameter ratio that ranges to 80:1.
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
MOLLART AMERICA Deep Hole Drilling Solutions
MMS Zones
Zones
