Die Grinders Efficiently Deburr, Grind Long Pipes
Dynabrade offers its line of 0.4-hp extension die grinders for efficient work within long pipes, castings and other part features requiring an extended reach.
Dynabrade offers its line of 0.4-hp extension die grinders for efficient work within long pipes, castings and other part features requiring an extended reach. These 25,000-rpm, straight-line air tools are available in either a front- or rear-exhaust air motor format and in lengths of 3" or 6" extension. Each die grinder features a safety-lock lever to prevent accidental startup of the tool. Dynabrade offers optional carbide burrs and mounted points for deburring, grinding, etching, cleaning and more.
