The DigiBore self-balancing boring heads offer a 0.118' to 8.195" boring range with coolant through the tool up to 580 psi at a maximum speed of 16,000 rpm. The "zero-out" function displays + or - fine adjustments in 0.0001" increments. The heads incorporate completely sealed electronic transversal measuring technology for 0.0001" accuracy, the company says.
Walter Launches New Solid Carbide Drill
The DC118 Supreme solid carbide drill provides high rigidity against deflection, superior centering accuracy and four margins with corner chamfers.
How Lowering Torque Improves Tapping Tool Life
Escaping the tap breakage trap requires a long look at torque and the many factors that influence it.
