DNC Box Enables CNC File Transfer via USB
Highland DNC’s ShopLink Flash USB-to-RS-232 adapter enables transfers of DNC program files to and from CNCs via flash drives.
Highland DNC’s ShopLink Flash USB-to-RS-232 adapter enables transfers of NC program files to and from CNCs via flash drives. Users simply plug a flash drive into the adapter and load the selected program into a CNC. The company says that the product accommodates newer PCs and laptops that do not come with serial ports. The ShopLink Flash also serves as a virtual 2-GB memory upgrade for CNCs with DNC or TAPE mode. The company says that it is better than a floppy emulator, which is limited to 720 K or 1.44 MB.
The package includes the ShopLink adapter, a 30" CNC cable, a 12-V power supply and a 4-GB flash drive. The device is said to work with all industry-standard CNCs with an RS-232 interface, including Dynapath, Fadal, FANUC, Haas, Mazak, Yasnac and others.
From Tradition to Transformation: Century-Old Manual Machine Shop Adds CNCs
After 122 years of working with manual mills and lathes, this fifth-generation shop acquired assets of a local CNC machining business and hired the owner. Here’s how it’s going a year later.
6 Steps to Take Before Creating a CNC Program
