Drill And Chamfer In A Single Operation
The Vex-S drilling and chamfering tool combines the company’s Snap chamfering system with the Vex twist drill in order to drill and front/back chamfer a through-hole in a single operation. The combination tool offers a solid carbide, replaceable twist drill tip with the company’s Vex cutting geometry, which is desi
New Product From: 8/5/2008 Modern Machine Shop
The Vex-S drilling and chamfering tool combines the company’s Snap chamfering system with the Vex twist drill in order to drill and front/back chamfer a through-hole in a single operation. The combination tool offers a solid carbide, replaceable twist drill tip with the company’s Vex cutting geometry, which is designed to create short clips in steel, aluminum and other long chipping material. It also has a helix chip gullet for chip evacuation. This self-centering drill tip features a Helica coating for extended tool life and can be reground and recoated for maximum cost effectiveness. The tool is suited for short hole drilling and smaller sizes, and it is available from 5 to 10.5 mm. The company offers 1 × D tooling from stock, while 2 × D and specials are available upon request.
Heule Tool Corporation
MMS Zones
Zones
Supplier Categories
ERIX tool saves up to 90% of the manufacturing time on back spotfacing and chamfering operations.
Premium tooling and technology for high-quality, precision machining.
Standard grooving tools from .004" in .001" increments with any corner radius. We stock more than 100,000 tools!
