Drill Combines Modular, Solid Carbide Characteristics
Widia’s Victory Top Drill M1 modular drill, part of the company’s Victory platform of advanced milling, turning and hole making tools, is said to combine the economic benefits of modular drilling systems with the machining performance and hole quality of solid carbide tools.Available over a standard diameter range of 0.3150" to 0.8264" (8 to 20.99 mm) and at length-to-diameter ratios of 3×D and 5×D, drill bodies are available in either flanged-shank (metric) or round-shank (inch) configurations.
Available over a standard diameter range of 0.3150" to 0.8264" (8 to 20.99 mm) and at length-to-diameter ratios of 3×D and 5×D, drill bodies are available in either flanged-shank (metric) or round-shank (inch) configurations. They feature solid coupling for consistent performance from insert to insert, and a front-clamping mechanism is said to ease insert changes.
Custom PCD Tools Extend Shop’s Tool Life Upward of Ten Times
Adopting PCD tooling has extended FT Precision’s tool life from days to months — and the test drill is still going strong.
Walter Offers New Solid-Carbide Taps for Blind-Hole Machining
Walter’s TC388 Supreme and TC389 Supreme feature patent-pending cutting geometries that fully shear off the root of the chip when reversing, thus minimizing torque peaks.
