Drill Designed for Versatility at an Economical Price Point
The DA110 Perform drill from Walter USA can be used universally and cost-effectively for a range of materials, the company says.
The DA110 Perform drill from Walter USA can be used universally and cost-effectively for a range of materials, the company says. It delivers higher accuracy with precision-ground surfaces and a tip geometry engineered for centering accuracy while keeping production costs down.
This HSS drill, with dimensions according to DIN 338 (jobber length), has a 118-degree point angle for more secure centering. It is available in grade WZ90AJ, which includes a TiN coating on the point, making it suitable for use machining ISO material groups P, M, K, N, S and O. The drill is available in diameters ranging from 1 to 16 mm, with increments every 0.1 mm.
Said to be ideal for small and medium-size batch production, the Perform line is designed to provide milling, threading and holemaking tools at a lower initial cost.
Custom PCD Tools Extend Shop’s Tool Life Upward of Ten Times
Adopting PCD tooling has extended FT Precision’s tool life from days to months — and the test drill is still going strong.
Walter Launches New Solid Carbide Drill
The DC118 Supreme solid carbide drill provides high rigidity against deflection, superior centering accuracy and four margins with corner chamfers.
