Drill Features Replaceable Cartridge System
The Revolution drill uses a replaceable cartridge design and allows adjustability ranging to 0. 200" (5. 1 mm) in diameter, which is said to eliminate the need for subsequent boring operations.
New Product From: 2/10/2009 Modern Machine Shop
The Revolution drill uses a replaceable cartridge design and allows adjustability ranging to 0.200" (5.1 mm) in diameter, which is said to eliminate the need for subsequent boring operations. The product is available in diameters ranging from 1.875" to 4" and lengths up to 4.5× diameter.
The company also features its Opening drill which is designed to enlarge existing holes, even on low-horsepower machines. This product consists of a diameter range of 2" to 5.62" and drill holders in 1× to 2.5× depth to diameter ratios. The drill holders are available with replaceable, adjustable cartridges. A proprietary insert is offered in AM200 and TiN coating as stocked standards. The drill can remove large amounts of material with only one pass, the company says.
Allied Machine & Engineering Corp.
