Specialized Plastic Packaging for Cutting Tools!
Drill Press Features Automatic Downfeed
Grizzly Industrial’s G0823 drill press with automatic downfeed is designed to provide precision and power for demanding jobs.
Grizzly Industrial’s G0823 drill press with automatic downfeed is designed to provide precision and power for demanding jobs. It is outfitted with a 2-hp motor, 12 speeds (which are adjustable using V-belts), an R-8 spindle taper, 15" of swing, fine downfeed control and a 14" × 15" precision-ground cast iron table.  Its table has rack-and-pinion mounts that enable 360 degrees of rotation, 60 degrees of tilt, 23½" of vertical travel and two ½" T slots for workpiece positioning. The head contains the same rack-and-pinion elevation controls as the table, so it is adjustable 7.8125" vertically and is capable of 360 degrees of rotation around the column. The work surface also has two additional ½" T slots.
GWS Tool Group
Ingersoll Cutting Tools
SGS
Iscar
Horn USA
Sumitomo
