Drills Feature Replaceable Cartridge Design
 The Revolution drill features a replaceable cartridge design allows users to adjust diameters up to 0. 200" (5. 1 mm), eliminating the need for specials or subsequent boring operations.
New Product From: 4/9/2009 Modern Machine Shop
The Revolution drill features a replaceable cartridge design allows users to adjust diameters up to 0.200" (5.1 mm), eliminating the need for specials or subsequent boring operations. The product is available in diameters ranging from 1.875" to 4.0" and lengths ranging up to 4.5× diameter.
The company’s Opening drill is designed to enlarge existing holes, even on low-hp machines. This product consists of a diameter range of 2.00" to 5.62" and drill holders in 1 to 2.5× depth-to-diameter ratios. The drill holders are available with replaceable, adjustable cartridges. The proprietary insert is offered in AM200 and TiN coating.
The BT-A drill introduces T-A replaceable tip technology. According to the company, the T-A drilling system inserts maximize penetration rates and tool life. The product works with standard BTA single-tube designs to flush spent coolant and chips through the tool. The drill insert is replaceable, so there is no need to regrind, and balanced cutting offers increased feed rates.
The GEN3SYS high penetration drilling system is designed to tackle ‘difficult-to-machine’ drilling applications. The company says the system improves hole quality, surface finish and true position when compared to competitive products. The replaceable drill insert allows for maximum machine uptime and reduces setup time.
Allied Machine & Engineering Corp.
MMS Zones
Zones
Supplier Categories
Standard grooving tools from .004" in .001" increments with any corner radius. We stock more than 100,000 tools!
Premium tooling and technology for high-quality, precision machining.
ERIX tool saves up to 90% of the manufacturing time on back spotfacing and chamfering operations.
Loading the player ...
