Drop Trunnion Tilting Rotary Table
Distributed by Koma, the Tsudakoma RT-111,AA drop-trunnion tilting rotary table features a design in which the top surface of the spindle is the center line of the tilt axis. Two pneumatic rotary joints on the rotary axis allow automated clamping/unclamping of the System 3R chuck and pallet system.
Distributed by Koma, the Tsudakoma RT-111,AA drop-trunnion tilting rotary table features a design in which the top surface of the spindle is the center line of the tilt axis. Two pneumatic rotary joints on the rotary axis allow automated clamping/unclamping of the System 3R chuck and pallet system. The trunnion table can also be equipped with chuck and pallet systems from Hirschmann, Erowa and various other manufacturers.
When To Use A Collet Chuck
