Dual-Belt Chip Conveyor Prevents Jamming
The MunchMan II twin steel belt conveyor from Jorgensen Conveyors is designed to handle large, stringy chips and balls of chips generated by milling and turning applications.
New Product From: 7/10/2014 Modern Machine Shop, , from Modern Machine Shop
The MunchMan II twin steel belt conveyor from Jorgensen Conveyors is designed to handle large, stringy chips and balls of chips generated by milling and turning applications. The updated conveyor features a drive system that uses one gear motor to run both drive shafts, a speed control function and a current overload sensor with the JamManager programming safety device. The company says the track has been reworked to enable rapid customer design modification and more efficient fabrication.
Compatible with a variety of CNC lathes and machining centers, the machine employs a stacked conveyor arrangement at the lower curve and through the incline and chip discharge. Primary and secondary cleated belts run in opposite directions to grab hold of chips and securely carry them up steep inclines, eliminating the risk of conveyor jams caused by chip balls tumbling back down the conveyor.
IMTS 2016 is right around the corner!
Now is the time to register for IMTS 2016, which runs September 12-17 in Chicago, Illinois. As the show approaches, please check our IMTS 2016 Zone for new product updates. We will also have information about new technology, pavilions to explore and conference information. In the meantime, check out IMTSTV for segments about the show and what’s new in the world of manufacturing technology.
Learn More about IMTS
Learn More
Jorgensen Conveyors, Inc.
Zones
We are inspired & innovative. IMTS is where solutions are found & professional goals are fulfilled. Register today!
  • Techspex
