Easily Upgrade Machines with Hexapods
If you are like me, you’ve never heard of a hexapod until recently (or now), but I put two and two together to figure out that it was a machining apparatus with six legs.
Article From: 12/22/2010 Production Machining, Lori Beckman,
If you are like me, you’ve never heard of a hexapod until recently (or now), but I put two and two together to figure out that it was a machining apparatus with six legs. I did a little more research on the topic to find that I was right (every now and then that college degree comes in handy).
A hexapod is an attachment that consists of six telescoping struts and converts conventional machining centers, boring mills, gantry mills and similar machines into machines that produce parts on a single setup compared with several operations on a conventional machine.
The hexapod attachment’s struts are paired around a fixed plate at one end. They converge at the other end to support a moving plate that supports a high speed machine spindle. The telescoping struts of the hexapod machine operate simultaneously to locate and orient the spindle. Also, whereas the original design of a conventional machine tool limits the movement capabilities, the hexapod machine makes it suitable for three-, four- and five-axis machining because it allows unlimited spindle orientation.
For more information about hexapods, visit “This Hexapod You Can Work With” and “Change Your Machine to a Hexapod.”
According to these sources, programming a hexapod machine is simple and requires no postprocessor. Another advantage is that it can be a more affordable way to enjoy the advantages of more efficient machining.
Editor's Picks
Take a standard knee-mill, identical to those found in thousands of shops around the world. On the backside of the mill, place a worktable. Under t...
Change Your Machine To A Hexapod
Want a hexapod machine but having trouble justifying the investment during these difficult times? Then you'll be interested in this hexapod attachm...
MMS Zones
Editor's Picks
Zones
Supplier Categories
KOMA Precision, the finest the world has to offer in machine tool Productivity Innovation.
