EDM, Five-Axis Milling Technologies
The CUT 200 wire EDM is designed to provide faster spark-to-spark wire threading, increase energy efficiency and boost productivity when cutting parts of variable heights.
New Product From: 5/2/2011 Modern Machine Shop
The CUT 200 wire EDM is designed to provide faster spark-to-spark wire threading, increase energy efficiency and boost productivity when cutting parts of variable heights. The machine also offers higher flexibility through its ability to reliably hold tolerances measured in microns over a range of part sizes. It integrates the Power Expert smart module, which continuously calculates part thickness, checking flushing pressure and adjusting machine power accordingly. This prevents wire breakage when changing the part thickness being machined. The diesinking Form 20 will also be on display along with the HSM 400U LP, a five-axis, high-speed milling center and the Drill 20 high speed vertical drill.
Agie Charmilles
MMS Zones
Agie Charmilles
Zones
Supplier Categories
