Emuge-Franken Celebrates 100th Anniversary
The company was begun by Richard Glimpel in 1920, who invented a spiral-pointed tap that could do with one tool what it normally took three to accomplish.
Emuge-Franken, manufacturer of taps, thread mills, drills, end mills and other rotary cutting tools, is celebrating its 100th anniversary.
In 1920, Richard Glimpel, a German engineer, invented a tap with a spiral point that changed the process of making internal threads, outperforming the three-part tap set by enabling the use of only the one tool. The new tool was so successful it helped secure a large order and growth for the fledgling company that Mr. Glimpel and three employees had started. In 1956, Helmut Glimpel, son of the founder and current owner, joined the company. In 1958 Emuge acquired Franken, a manufacturer of milling tools, and changed its name to Emuge-Franken. In 1983 the company established Emuge Corp. in the United States, which recently expanded its facility in West Boylston, Massachussets. Today, Emuge-Franken has more than 1,900 employees with locations worldwide.
Moving forward, Emuge-Franken has committed to further expansion. Construction is now underway to build a new 215,000-square-foot production facility opposite the current global headquarters in Lauf, Germany. The facility, slated to be fully operational by 2023, will enable significant manufacturing capacity increases, the company says.
Walter Offers New Solid-Carbide Taps for Blind-Hole Machining
Walter’s TC388 Supreme and TC389 Supreme feature patent-pending cutting geometries that fully shear off the root of the chip when reversing, thus minimizing torque peaks.
Walter Extends Line of Precision Boring Tools
The new boring tools employ modular components such as cartridge holders and extensions, which are matched to the system, utilize an extensive range of indexable inserts suited for precision boring and can be used for all material groups.
Custom PCD Tools Extend Shop’s Tool Life Upward of Ten Times
Adopting PCD tooling has extended FT Precision’s tool life from days to months — and the test drill is still going strong.
