End Mills, Other Technologies on Display
Haimer will showcase a variety of newer products, including Power Mill end mills featuring the company’s Safe-Lock system, which is designed to act as a “seatbelt” to protect against pull-out from the holder.
Haimer will showcase a variety of newer products, including Power Mill end mills featuring the company’s Safe-Lock system, which is designed to act as a “seatbelt” to protect against pull-out from the holder. It also will highlight its Duo-Lock modular milling interface, which includes self-fitting thread technology for high load capacities, high rigidity and increased runout. According to the company, combining these technologies with its Shrink Fit Chucks, Power Collet Chucks and Cool Flash systems will enable increased metal removal rates and maximized applications.
Haimer also will featuring its latest balancing machines, shrink-fit machines and 3D-Sensor innovations.
