End Mill’s Truncated Radius Avoids Wear
SwiftCarb offers its XT7 RampMill seven-flute end mill, with an end geometry that enables helical ramp engagement to 8 degrees in steel and exotic metals.
SwiftCarb offers its XT7 RampMill seven-flute end mill, with an end geometry that enables helical ramp engagement to 8 degrees in steel and exotic metals. The center hole delivers coolant or air to blast chips away, eliminating re-cutting operations and dramatically increasing tool life, according to the company. The mill’s truncated radius adds corner strength and avoids the wear points of a traditional radius.
