Entry-Level Factory Automation Solution
The compact Kiwa-Japan KH-41 HMC is 60. 2" (1,530-mm) wide and can handle a variety of workpieces, providing an ideal entry-level factory automation solution, the company says. The HMC has a full rotary B axis and can be installed in the same space as a vertical machine.
New Product From: 4/9/2009 Modern Machine Shop
The compact Kiwa-Japan KH-41 HMC is 60.2" (1,530-mm) wide and can handle a variety of workpieces, providing an ideal entry-level factory automation solution, the company says.
The HMC has a full rotary B axis and can be installed in the same space as a vertical machine. With a 400-mm pallet machine, the HMC can accommodate workpieces as large as 21.7" × 33.5".
The machine design emphasizes maximum space utilization, rigidity and speed, the company says. The drum-style ATC is said to provide speed, accuracy, rigidity and reduced cycle time. Acceleration of 1G is standard on all axes.
KOMA Precision, the finest the world has to offer in machine tool Productivity Innovation.
Power of Evolution.
