Entry-Level Waterjet for Production Environments
MC Machinery Systems’ entry-level MWX3 waterjet machine is designed for production environments.
New Product From: 7/12/2012 Modern Machine Shop
MC Machinery Systems’ entry-level MWX3 waterjet machine is designed for production environments. It features a solid-base construction and cantilever head design with a M720 CNC. The machine is equipped with a high-pressure S-50 KMT pump, which provides 60,000 psi of water traveling up to Mach 2 with 1.09 gpm of water consumption through a maximum orifice size of 0.013".  The reciprocating hydraulic piston to ceramic water piston ratio is 20:1, pushing the water into an accumulator that maintains a smooth, even flow to the cutting nozzle.
MC Machinery Systems will display its wire EDM cylindrical drive technology, Waterjet series and MC Milling line.
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
Mitsubishi EDM
MMS Zones
Mitsubishi EDM
Zones
