Environmentally-Friendly Cleaner Removes Difficult Soils
Kyzen’s Metalnox M6324CP is a heavy-duty alkaline cleaner and inhibitor.
Kyzen’s Metalnox M6324CP is a heavy-duty alkaline cleaner and inhibitor formulated to remove paraffinic oils used in a wide range of machining, stamping and deep draw operations. It is built with effective steel corrosion inhibitors to provide long-term protection from rust.
The product can remove difficult soils, including carbon smut and chlorinated oils, and it provides effective steel corrosion protection for as long as 90 days. It also provides environmental advantages as a nonflammable, alkaline, biodegradable aqueous solution.
Oelheld Coolant Increases Metal Removal Rates
The odorless coolant is said to offer increased removal rates, lower electrode wear, excellent surface qualities, lower refill quantities and longevity to provide lower overall operating costs.
AFT's Semi-Synthetic Coolant Extends Sump Life
Advanced Cool 2200 provides high visibility while machining, keeping the machine and parts clean with no odor issues.
High-Speed Videos Analyze Machining Processes in Fine Detail
Blaser Swisslube captures the machining process, chip formation and behavior of its Synergy 735 metalworking fluid through high-speed, macro photos and videos.
