Good morning, and welcome to our Webinar this morning with
Makino. My name is Tim Jones, I’m the Horizontal Product Line Manager
here at Makino. Our topic this morning will be Error Proofing the
Machining Process.
I chose the topic of Error Proofing the
Machining Process because I thought it would provide a lot of
beneficial information to our listeners. Most, if not all, of you have
at least been aware of or familiar with lean initiatives, and many of
you have been trained in lean initiatives.
The main topic
of lean initiatives is eliminating waste from the manufacturing
process. A lot of that waste is created by errors in the process that
can occur. It’s not necessarily anybody’s fault, but they occur
somehow, and we’re going to cover some of those areas that are the most
likely places where errors can occur in the machining process.
As
we’ve developed the error proofing, for today’s Webinar, I just wanted
to comment on why I thought this topic might be relevant to our
listeners. Number one is because of the global economy and our
continuing quest to become more competitive in our own business.
Certainly, we need to reduce costs and one of the major areas of cost
increases can come from errors that might occur in a manufacturing
process when you think about scrap and things like that.
The
other thing that I believe is really important is the lean initiatives.
Most of you have been very aware of lean manufacturing processes and
techniques. Many of you have actually been trained in them and, as you
know; lean initiatives are centered around waste and getting rid of
waste and errors in the manufacturing process.
The way I
approach this topic is to go down through the flow of manufacturing as
you're thinking about producing your parts. When you get a new part to
produce within your manufacturing processes, one of the first things
you do is develop how you're going to hold the part, your history and
your processes.
I want to go through the same flow that you
may go through in developing a part process. First of all, we’re going
to kind of look at fixtures and what we can do with error proof
fixtures and holding the part to reduce errors. The second thing we
want to look at equally as important, of course, is the tooling.
Programming is another big area, especially as we’re looking at
environments that would include both low volume type production and
high volume production, because obviously there's big difference in the
two.
But, programming is a key piece of this and the machining
process, and what can you do on the machine itself to improve the
process in terms of eliminating errors? We’re going to talk about that
and if we can do all this better and with more efficiency and less
errors. Obviously, we can then offer better deliveries and be more
consistent in on time deliveries. In all that, you want your customer
to be satisfied so they come back to you for more services. We’re
going to kind of go through that flow.
