In our business, we’ve discussed some of the typical errors through
talking to a number of our customers and simply being around the
industry for 25 years. Sometimes process steps may get missed. This may
be due to a number of reasons, like familiarity with a process by an
individual or some printing issues, or work constructions, or miss-set
work pieces. This can be very common for a number of reasons. Again,
we’re going to talk about some of the ways that we can eliminate these.
All these are the most typical areas that may occur. The bottom line is
all of these things will basically cause waste, and we want to
eliminate the waste. We’re going to talk about some ways to do that.
Why
implement effective error proofing? One is the competitive advantage
you get. By eliminating error proofing, you're going to improve your
quality overall; it’s going to give you a better global
competitiveness. Secondly, you're going to reduce your cost because
you're preventing errors, and it costs less to prevent an error than it
does to correct or catch one later and then have to do the re-work to
make the part good. It costs less to prevent errors than it does to
catch them later; that’s a key point.
Obviously, reducing
scarp that might be caused by some error in the process is going to
reduce your materials cost and it’s going to reduce your labor costs
for re-work, and it’s going to improve your delivery. You can expect
less scrap due to less error. With effective error proofing processes
you're also going to reduce your work, your raw material and work and
process inventories.
I took kind of informal survey from
our own people and some of our customers to ask, ‘what is the scrap
rates in the industry today?’ I took a shot with some people that have
the experience and I came up with this figure: scrap rates are two to
six percent, depending on the flexibility of the part and maturity of
the process.
What we mean by this is that in a low volume
environment where you're constantly doing short run parts and you're
doing a lot of first time parts, there's going to be a higher scrap
rate than if you're doing a 100,000 parts a year. You go through the
prove out and the initial stages of producing a part where you're going
to have more errors occurring, but once that higher volume production
becomes more mature, the percentage of scrap should go down
significantly.
It depends on a lot, but two to six percent,
roughly, is what we’re saying might be the scrap rates that are
occurring in our industry today. That doesn’t apply to everybody, but
it’s very general. Short term versus long term production has a big
impact on that percentage. Again, the scrap rates have a huge impact on
your bottom line, which is why we want to talk about error proofing.
How
does error proofing relate to lean? I mentioned briefly at the
beginning that lean is all about eliminating waste and the specific
point within lean, for those of you that have gone through the training
you know the term, ‘Poka-yoke.’ That’s a Japanese term, as lean really
originated in Japan. What we want to accomplish is that any error that
does occur needs to be found to deliver a perfect part to that next
step in the process.
Here’s a look at the seven areas
of waste as identified in lean manufacturing principles: inventory,
processing, correction, overproduction, motion, material movement and
waiting.
Error proofing can impact every one of those. For
example, for over production there may be a decision in the
manufacturing environment to overproduce a part because you have an
expected certain scrap rate and have overproduced the parts. Basically,
you’ve introduced waste into the process and with effective error
proofing, good processes and so on. You can impact and eliminate the
need for overproduction, which is one of the seven areas of waste in
lean manufacturing. But, certainly, error proofing the manufacturing
process can impact every one of these seven areas of waste as
identified by lean principles.
