Staying with the programming theme, there have been some things that
we’ve done here at Makino. Historically, we do turnkeys for a lot of
our customers; we’ve done around 450 different part configurations for
our customers. I have a lot of experience with processing and
programming, myself. One of the things we do is put Safe Star
programming techniques into all of our turnkey projects and what this
does is to eliminate errors when we start programs. Often times, for
one reason or another, as you know on the manufacturing floor, there
would be a need to restart a program from somewhere midway through the
part program. When that event occurs, there's always a higher risk of
something going wrong. We want to eliminate those risks and eliminate
those errors by putting a Poka-yoke process in.
What we do
is use something called a safety line. The first line of the program is
a safety line and the safety line establishes conditions under which
the CNC will operate. There's an example down below of a safety line
that would be put into the beginning of a part program. The safety line
then should also be located before each tool change, which will allow
an operator to safely restart programs.
The reason for
this is a safety line will cancel out and establish kind of a baseline
condition for the machine tool at every tool change. Then, with the new
tool in your part program you're going to be establishing and
re-establishing the conditions in which you want the machine to operate
with this new tool, in terms of your offsets, work offsets, your tool
offsets, cut radius compensation—whether you're running an inch or
metric motor, all of these different G-codes. It’s easy to do this and
it can go a long way in terms of eliminating errors that might occur if
you have to start midway in a part program, which often occurs as we
all know in a real manufacturing environment. This is a Poka-yoke
process that we at Makino have put into all of our programs to
eliminate errors. Again, it’s to reduce cost and all the things that
are associated with errors in the manufacturing process.
We
have another slide to review that is useful in high speed machining
processes. This is a little bit different than the other things that
we’ve been talking about so far because this is actually a technology
built into the servo motion control system of the machine tools. It is
a Makino feature called, “Geometric Intelligence.” I think it
qualifies as an error proofing process is because for high speed
machining.
Typically, you’re machining at feed rates
anywhere from 100 inches a minute to 300 to 500 inches a minute. It is
with aluminum you can machine at those kind of feed rates and, often
times, it’s going to be in some kind of a hog out situation in the
aerospace industry, like an air frame component, or where there's a lot
of material to be removed. Geometric Intelligence, what we call GI.3 or
the version three of the software capability, becomes less operator and
programmer dependent to produce a good part at the feed rate you
desire.
To explain this a little bit more, my slide has
four different columns. The one on the left says, ‘Radical Mode,’ and
the one on the right is ‘Ultra Precision Mode, and there's an M code
associated with each one of those. The reason it’s an error proofing
process is you can chose the M code and basically program the machine
to perform at the level you need for a given application.
For
example, if I’m machining an aerospace airframe component and I've got
pocket tolerance from side to side that is plus or minus five
thousandths, and that’s somewhat typical in a lot of the air frame
components, I want to get material out there just as fast as possible.
I can put in my part program an M2-55 which happens to be what we call,
‘Radical Mode.’ I’m not terribly concerned with the accuracy, but I am
concerned with going as fast and removing as much metal in the least
amount of time as possible to reduce my cycle time. I can program and
run the machine under M2-55.
Now, if I’ve got a feature
in that part where I need to hold a much closer tolerance, of a half a
thousandths on pocket size, I don’t want to do that. I can simple
program the machine, again with an M code to say, ‘Okay, I want to hold
a very tight tolerance.’ What that means to the machine tool,
considering the inertia and everything of the machine, the machine will
operate and this is when the intelligence part of the feature is
called. It will operate to obtain the tolerances that you’ve programmed
the machine to achieve.
And, it takes no judgment from the
programmer in order to achieve this. The programmer can still write in
500 inches a minute, but he’s still going to get ultra precision if he
programs the machine to perform that way. The machine’s not going to run 500 inches a minute, but
it’s going to do what it needs to do to achieve a tolerance programmed
into the part program.
The reason this falls into error
proofing is that a programmer can make a judgment that will later be
proved incorrect and cause a scrap part or a problem in the finished
result. The machining result of that part with the GI function means
that all the programmer needs to do is put in the proper M code based
on the accuracy that he or she needs, and the machine does the rest and
an error is very unlikely. That’s why this belongs in the error
proofing discussion we’re having today.
