Expanded End Mill Line
Primary Cutter’s expanded Supermill-XP end mill line is available in chamfer, corner- radius and sharp-corner styles, as well as in regular, stub, long and extra-long lengths. The variable-pitch end mills feature a four-flute design and a 45-degree helix angle.
Primary Cutter’s expanded Supermill-XP end mill line is available in chamfer, corner- radius and sharp-corner styles, as well as in regular, stub, long and extra-long lengths. The variable-pitch end mills feature a four-flute design and a 45-degree helix angle. They are available in diameters ranging from 3/16" to 1" and can be furnished with Alcrona or Xceed coating. The end mills are designed for heavy metal removal in materials such as superalloys, titanium, stainless steels and more in the aerospace and medical industries, among others.
Five-Axis Changes Weldments Into Monolithic One-Piece Parts
Moving from welding to five-axis machining enabled Barbco to redesign its weldments as monolithic one-piece parts with improved strength and repeatability.
