Expanded Line of Pre-Settable, Quick-Change Tooling Systems
Göltenbodt, represented in the United States by Schwanog, introduces its new generation of toolholders for Tornos MultiSwiss 6×4 and Star Swiss-type automatic lathes.
Göltenbodt, represented in the United States by Schwanog, introduces its new generation of toolholders for Tornos MultiSwiss 6×4 and Star Swiss-type automatic lathes. The toolholders are pre-settable in the X, Z and Y axes out of the machine, while repeatability is 0.0002". Coolant-though holders with pressure ratings as high as 500 psi are available. The rigid design is said to provide chatter-free operation, reliability and increased tool-life. The company also offers dovetail, shave, stick tool and cutoff holders with internal coolant. The holders are designed to accept a variety cutting tool brands.
Making the Most of Mixed Toolholder Assemblies
While nearly all ER systems will have cross compatibility, they’ll have small differences across manufacturers that make their implementation at the shop level not as standard.
