Extended End Mills for Deep Cavity Milling
Midwest Cutting Tool’s extended-reach carbide end mills provide high performance for deep-cavity milling.
Midwest Cutting Tool’s extended-reach carbide end mills provide high performance for deep-cavity milling. The full line includes flat and ballnose mills ranging from 4" to 14" in length and to 1" in diameter. The line offers two- and four-flute configurations. These end mills are designed for chatter-free performance and long tool life. Custom extended-reach mills are also available.
Best Practices: Machining Difficult Materials
