Extra High Chuck Jaws Improve Workpiece Stability
DMI Series H extra high chuck jaws from Dillon Manufacturing with heights available to 10” tall are featured in the company’s booth.
DMI Series H extra high chuck jaws from Dillon Manufacturing are available with heights ranging to 10". The longer lengths are said to provide better workpiece stability, and enable multiple uses of the blank before it is consumed. The extra length eliminates the additional time and costs associated with welding and bracing needed to lengthen standard height top jaws. Manufactured from 1018 steel, 4140 steel or 6061 aluminum, the jaws are available in all standard chuck mounting styles, and are sutiable for precision boring, tapping, drilling and finishing.
Machining Vektek Hydraulic Swing Clamp Bodies Using Royal Products Collet Fixtures
A study in repeatable and flexible workholding by one OEM for another.
Moving To Magnets Doubles Productivity
