Horn USA
Face-Grooving Adapters Cover Larger Diameters
Iscar has expanded the application range of its HGAIR/L and HFAIR/L face-grooving adapters.
Iscar has expanded the application range of its HGAIR/L and HFAIR/L face-grooving adapters. The range applies to both diameters and grooving depths of 3- to 6-mm inserts. The adapters are designed to cover larger diameters and deeper grooving ranges not possible with previously available tools. They are well-suited for use on larger workpieces such as pump hubs, hydraulic parts, turbine parts and engine pistons.
GWS Tool Group
Sumitomo
Iscar
Horn USA
IMCO
SGS
Ingersoll Cutting Tools
Horn USA
