Face Mill Offers More Cutting Edges
The hi.aeQ face-milling cutter from Komet of America is said to be ideal for shoulder and face milling of cast iron workpieces, as well as counter-boring and milling operations.
New Product From: 8/27/2014 Modern Machine Shop, ,
The hi.aeQ face-milling cutter from Komet of America is said to be ideal for shoulder and face milling of cast iron workpieces, as well as counter-boring and milling operations. The nickel-plated body of the face mill features tangentially positioned Q80 indexable inserts, which are fitted in an alternately standing/lying arrangement. Each indexable insert has eight usable cutting edges for greater cost effectiveness. In addition to offering a high number of cutting edges relative to the tool diameter, the design promotes stability and limits vibration in the cutter. A special coolant sleeve ensures that coolant is equally distributed to every cutting edge, ensuring optimal tool life. According to the company, the cutting tool’s benefits include higher cutting efficiency and lower power consumption, as well as quieter operation and reduced spindle loads. The hi.aeQ face mills are available in diameters ranging from 63 to 160 mm, enabling a range of uses. The Q80 inserts are available with a PVD TIALN or a CVD TICN, TIN aluminum oxide coating.
IMTS 2016 is right around the corner!
Now is the time to register for IMTS 2016, which runs September 12-17 in Chicago, Illinois. As the show approaches, please check our IMTS 2016 Zone for new product updates. We will also have information about new technology, pavilions to explore and conference information. In the meantime, check out IMTSTV for segments about the show and what’s new in the world of manufacturing technology.
Learn More about IMTS
Learn More
Komet of America, Inc.
Zones
We are inspired & innovative. IMTS is where solutions are found & professional goals are fulfilled. Register today!
  • Techspex
