FANUC's CRX-10iA Cobot Safely Handles 10-kg Parts
FANUC America’s CRX-10iA and CRX-10iA/L (long arm version) collaborative robots are said provide ease of use, reliability and safety with parts weighing up to 10 kg.
FANUC America’s CRX-10iA and CRX-10iA/L (long-arm version) collaborative robots are said provide ease of use, reliability and safety with parts weighing up to 10 kg. The CRX-10iA and CRX-10iA/L provide a reach of 1,249 mm and 1,418 mm, respectively. Sensitive contact detection enables them to work safely alongside people in a variety of industrial and manufacturing jobs, the company says.
According to FANUC, the cobots are easy enough to set up that someone with no experience using a robot can do so. The lightweight, compact arm is intended to fit a variety of floor configurations. The long-arm version uses a swing motion to access parts behind it.
A compact R-30iB Plus Mini controller provides lead-through teach programming and a new tablet interface with icons for touch control. No programming knowledge is required, FANUC says. The robots also support FANUC’s integrated iRVision and iRPickTool software.
View From My Shop Video 1: A Deep Dive Into Automation with Advance CNC
Advance CNC leverages multiple forms of automation to increase its milling machines' productivity. Learn more in this episode of The View From My Shop.
