WEIMA
Filterless Air Mist Collector Efficiently Eliminates 3-Micron Particles
Tecnara Tooling Systems introduces the Aoi MistCapture, a filterless air mist collector that is said to provide 98 percent efficiency in eliminating three-micron particles.
Tecnara Tooling Systems introduces the Aoi MistCapture, a filterless air mist collector that is said to provide 98 percent efficiency in eliminating three-micron particles. The product is available in four models designed for a range of air volumes, velocities and applications. The collector is designed to be compact and easy to mount, and can be fine-tuned for environments where contaminants are a problem.
The impeller uses centrifugal force to separate out particulates and is sound-attenuated for quiet operation. Only purified air is emitted from the exhaust port. Regular maintenance can be performed without removing the duct hose from the intake port.
To facilitate servicing, the product is designed for floor or low-stand installation. A dedicated stand is available. The air intake may be located as far as 25 ft. from the filtration system. Operating air temperature ranges to 140°F (60°C) at the intake plate. The product can be used for a variety of applications including machining centers, lathes and multi-task machines.
The view from my shop.
WEIMA
