Five-Axis HMC Machines Titanium
Makino’s T2 five-axis HMC with Advantige technology is designed for mid-sized titanium aerospace part production.
For continuous operation, the machine includes an automatic pallet changer system (60 sec. change times) to eliminate downtime for part change-overs. The machine can also be integrated with an automatic pallet transfer and storage system in a flexible Makino Machining Complex (MMC) automation system for extended periods of unattended operation. This system assigns work and initiates operations automatically, maximizing spindle utilization for increased productivity.
