Five-Axis Vertical Machining Center Features Robot Interface
Eastec 2019: The MX-520 PC4 is designed in response to customer demand seeking a Matsuura automation solution for the MX-520.
Yamazen will showcase Matsuura’s MX-520 PC4 five-axis VMC in its booth. The MX-520 PC4 is designed in response to customer demand seeking a Matsuura automation solution for the MX-520. The machine is equipped with 90 tools and an installed Universal Robot Interface to maximize its automation potential. The machine is described as offering ease of use and reliable five-axis machining. The MX series of which it is a part is marketed as delivering machine versatility, high accuracy, reliability and cost-efficient performance.
The Matsuura MX-520 is designed for high rigidity, offering a large machining envelope. The vertical machining center is also available in an assortment of configurations in order to accommodate all applications, industries and materials. Designed with a RAM type structure, the machine has a compact footprint with ergonomic features said to enable rapid setup and processing of complex parts.
The company says the MX-520 is a cost-effective machine for three-axis users making the transition to full five-axis operation.
Five-Axis Changes Weldments Into Monolithic One-Piece Parts
Moving from welding to five-axis machining enabled Barbco to redesign its weldments as monolithic one-piece parts with improved strength and repeatability.
Why Go Five-Axis: Machine Types and Benefits
