Five-Axis VMC Achieves Workpiece Accuracy
The Kern Micro five-axis vertical machining center from Kern Precision is suitable for machining nanoscale to large-sized parts.
The Kern Micro five-axis vertical machining center from Kern Precision is suitable for machining nanoscale to large-sized parts. It can accommodate workpieces ranging to 350 mm in diameter and 220 mm in height within a compact footprint. According to the company, the machining center provides accuracy ranging to ±0.5 microns, with achievable workpiece accuracy ranging to ±2 microns, delivering high repeatability for reliable and productive operation.
The machine’s workpiece palletization system features a System 3R Macro Mangum or Erowa Power automatic chuck as a pallet receiver. The tool cabinet with quick-change pallet can hold more than 200 tools. The machining center also is equipped with an automatic laser tool measuring system, a workpiece probing system and a temperature-control system for maintaining accuracy.
