Available from YMT, the Quaser MF500 five-axis machining center can accommodate a 19.7" × 11.8" maximum workpiece size. It features 21.7" × 31.5" × 24" X-Y-Z travels, and is well-suited for complicated workpieces that require multiple setups.
In addition to other machines, the company will also display the Quaser Travel Column five-axis machining center with 111" × 22" × 28" X-Y-Z travel and a built-in rotary table that is capable of handling parts up to 22” diameter and 24” tall for five-axis machining. It offers a B-axis 58-hp/12,000-rpm built-in spindle motor and dual 48T and 60T ATC units for ultimate flexibility.
More technology – a lot more!
Learn More about IMTS 2012
