Okuma
Flat-Bed Lathes Promote Rigidity
Acra Machinery’s FEL-2600 series CNC lathes feature rugged Meehanite castings with thick, widely-spaced cross supports and induction-hardened ground ways to provide maximum accuracy and rigidity.
Acra Machinery’s FEL-2600 series CNC lathes feature rugged Meehanite castings with thick, widely-spaced cross supports and induction-hardened ground ways to provide maximum accuracy and rigidity. The versatile flat-bed lathes are available in five different models with X-axis travels ranging from 18" to 21.5" and Z-axis travels ranging from 40" to 160". Swing over the bed is 26". Precision-ground oversized ballscrews are driven by AC digital servomotors. The 4.72"-bore spindle provides speeds ranging from 6 to 2,000 rpm with 30 hp. Spindle bores of 6.6" and 7.1" are also available. The lathes are equipped with a FANUC OT control, and accessories include a high-powered coolant system and coolant pan; vertical octagon servo turret; hydraulic tailstock; MT 5 moving center; and steady rest/roller.
  • Choosing Your Carbide Grade: A Guide
  • Deep Hole Drilling Without Drift
    A deep hole drill with intuitive controls and minimal hole drift was one shop's pipe dream — until the shop helped a machine tool builder make it.
  • Modern Bar Feeds Bring New Life to Automatic Swiss Lathes
    Cam-actuated Swiss lathes are still the fastest way to process many parts. By adding modern bar feeders, this shop has dramatically improved their utilization with the ability to work unattended, even in a lights-out environment.
Okuma
