Floating Plate Takes The Run . . . Out
Understanding the critical role of the grinding operation in the shop's manufacturing process, grinding machine makers continuously apply the best technical knowledge available to their machines. Often these are little innovations that help reduce the opportunities for inaccuracy to seep into the process. A typical example of such innovation is found in this manufacturer's line of grinding machine tools.
Article from: Modern Machine Shop
Posted on: 2/15/2000
Grinding machine tools
This chart
This chart compares the difference in smoothness between simultaneous feed of two axes on a machine with the Toyoda floating plate and one without. The traverse distance is 18 mm. Accuracy was 1 micron without the floating plate, which was improved to 0.3 micron with it.
This schematic drawing
This schematic drawing shows the position of the floating plate on the wheelhead slide. Ballscrew runout is absorbed by this patented device.
In most of the metalworking steps that precede the precision grinding operation, there is some room in the process for a little extra stock to be left. It’s the grinding operation where the final size and finish are imparted. Basically, precision grinding leaves no room for error. The operation either hits the part specification tolerance or the whole series of manufacturing steps must begin again.
Understanding the critical role of the grinding operation in the shop’s manufacturing process, grinding machine makers continuously apply the best technical knowledge available to their machines. Often these are little innovations that help reduce the opportunities for inaccuracy to seep into the process. A typical example of such innovation is found in the Toyoda Machinery USA (Wixom, Michigan) line for grinding machine tools.
Most grinders actuate the machine tool’s axes using ballscrews. Precisely manufactured, ballscrews are a well-known and reliable means of moving machine tool components. Application of powerful CNC and fast feedback servo technology make the ballscrew accurately responsive to very small motion commands.
In OD grinding there are two axes that come into play. The Z axis is generally the reciprocating table that carries the workhead, footstock and workpiece. The machine’s X-axis moves the wheelhead, or heads, into the work zone. In many applications these two axes are used in concert to profile grind the workpiece.
The ballscrews that actuate these axes are engineered to be stiff and manufactured to be straight. In reality though, no ballscrew is infinitely stiff or perfectly straight. These deviations from perfect are runout. An exaggerated analogy of ballscrew runout is rolling a bent cue stick on a pool table.
In operation there are two primary sources for ballscrew runout. Dynamic runout, which is also called “wind-up,” is caused when a ballscrew deflects slightly as it overcomes inertia. Static runout is the ballscrew’s deviation from perfectly straight.
To compensate for these realities, Toyoda uses a patented device they call a floating plate. It’s designed to prevent transfer of ballscrew runout to the Z-axis table or X-axis wheelhead by absorbing the runout.
The mechanism is mounted under the slide and on the base of the machine. Both X and Z-axis ballscrews are supported. Instead of coupling the ballscrew directly to the machine’s moving element through a rigidly mounted ballnut, the ballscrew is connected to the table or wheelhead using a floating plate.
Imperceptible movements between the ballscrew and the floating plate compensate for misalignment that could result when the grinding wheel makes contact with the part. The design of this plate allows the screw to oscillate in a radial direction, which prevents any runout from affecting the moving components. Maintaining tolerances and eliminating bind between the moving element and the ballscrew helps ensure precision grinding.
Granted, the effects that the floating plate neutralizes are generally very small. But in precision grinding, inaccuracy is an accumulation of very small effects. Eliminating as many as possible will result in a more precise and predictable grinding process. And that, after all, is the goal.—GCK
