Goniometer Eyepiece Extends Modular Tool Microscope
Titan Tool Supply has added the AME-5M angle measuring goniometer eyepiece to its modular tool microscope system.
Titan Tool Supply has added the AME-5M angle measuring goniometer eyepiece to its modular tool microscope system. The AME-5M measures 360 degrees to an accuracy of 5 min. by use of a rotary Vernier and crosshair eyepiece. It features a white scale on a black background and can be enlarged by a 10× magnifier. The company says the eyepiece is ideal for checking cutting tool geometry and angular measurement.
The AME-5M eyepiece is optimized for use with the Titan Tool modular tool microscope system. The modular concept enables magnifications ranging from 3× to 800× using a choice of three body styles, three mounting brackets, two illuminators and two video adapters. All images produced are optically correct, and parts may be used individually or assembled together to create a measuring microscope.
MMS Top Shops
Gravotech
The view from my shop.
