Graphite Mill Armed with Oil Cover to Capture Dust
EDM Network will exhibit its HM43GT high-speed graphite milling machine, which features an “oil shroud” option that completely surrounds the 30,000-rpm spindle with EDM-compatible oil to capture all of the graphite dust created by the end mills.
EDM Network will exhibit its HM43GT high-speed graphite milling machine, which features an “oil shroud” option that completely surrounds the 30,000-rpm spindle with EDM-compatible oil to capture all of the graphite dust created by the end mills. The “dust-free” machine can also be equipped with a vacuum system as well as Blum laser diameter compensation, three-axis glass scales and other options.
  • Inside an Amish-Owned Family Machine Shop
    Modern Machine Shop took an exclusive behind-the-scenes tour of an Amish-owned machine shop, where advanced machining technologies work alongside old-world traditions.
  • Choosing Your Carbide Grade: A Guide
  • Watchmaking: A Machinist’s View
Okuma
High Accuracy Linear Encoders
The view from my shop.
