Grippers for Smooth, Slippery Surfaces
The new Abrasive Diamond Surface Grippers from Fairlane Products has a surface comparable to 100-grit sandpaper bonded permanently to a stainless steel pad and is said to provide excellent non-slip gripping on smooth or slippery surfaces with minimal clamping force and surface marking.
New Product From: 4/5/2011 Modern Machine Shop
The new Abrasive Diamond Surface Grippers from Fairlane Products has a surface comparable to 100-grit sandpaper bonded permanently to a stainless steel pad and is said to provide excellent non-slip gripping on smooth or slippery surfaces with minimal clamping force and surface marking. The individual diamond particles transfer holding pressure to a very small and well-distributed area, in addition to providing effective wear resistance. These high-strength grippers are available in various sizes and configurations.
In addition, the manual clamps from Imao include miniature, swing, pull, push, rocker, snap and heavy-duty clamps with forces from 150 to 2,250 lbs. These retractable clamps, which are designed for repetitive or quick clamping operations, are made of durable alloy steel that is heat-treated and has a black oxide finish.
Fixtureworks
Fixtureworks
