Haimer USA Opens North American Headquarters
The new headquarters feature a showroom, training facilities and offices built to support the company’s continued growth.
Haimer USA, a subsidiary of Haimer GmbH, opened their North American headquarters in the Villa Park suburb of Chicago, Illinois.
The location features training facilities and an expanded showroom equipped with a CNC machining center for demo cuts, shrink-fit and balancing machines under power. Both the training facilities and showroom are equipped with HD cameras for live and web-based presentations.
The facility will also provide balance inspection, precision balancing and data chipping services for toolholders from Haimer or any other manufacturer. Future service offerings will include end mill regrinding as well as Safe-Lock groove modifications.
