Some of the technology enhancements that we have done to the machine
are as follows. We took our flushing nozzle technology into a better
design to help with the flow to the work piece. We have improved upon
our flushing capabilities themselves doing some things to our pump
systems. We have also extended the life of the carbides as a result of
the HEAT technology. We wanted to run with less intervals in our
carbide contact life. In our generator we've made many improvements to
our generator. One would be our Belly Wizard Technology which is a
mechanical and electrical wire path compensation. Meaning that we do
certain things to the XY and UV to compensate for the taper or belly
that you get in the part, to provide you will superior straightness.
Something that years ago you may have to accomplish with four five
maybe six trim cuts to get the same accuracy. We may be doing that in
one cut or maybe even one cut and one trim. So it's truly a unique way
of compensating the wire for straightness. And our Corner Wizard for
excellent shape accuracy in corners. So there is no slow down in
corners by using special algorithms to compensate for the corner error.
This is again the technology that some of our competitors have but I
think that Makino has refined this into a science. Our Power Wizard
again you could compare it to some of our competitors' automatic power
compensation but it really slows down the machine. With Makino's since
we are using scales and end coaters we have superior feedback. That's
standard on our machine allowing us to search for the highest speed
possible and search for the most constant advance even under extreme
conditions.
