High-Feed Cutter Features Six Edges
The Power-Feed+ high-feed cutter utilizes a trigonal-shaped insert with six cutting edges designed for performance and economy. The insert was engineered for high speed machining and features strong, heavy edge prep as well as durable, wear-resistant substrates and coatings, the company says.
New Product From: 4/30/2009 Modern Machine Shop
The insert technology is mated to a series of robust cutter bodies that allow end-users to maximize their high speed machining potential, the company says. The cutter bodies incorporate features such as through-coolant and heavily supported backing behind the inserts. They are constructed of premium H13 and 4340 steel materials.
Ingersoll Cutting Tools
MMS Zones
Zones
Supplier Categories
ERIX tool saves up to 90% of the manufacturing time on back spotfacing and chamfering operations.
Standard grooving tools from .004" in .001" increments with any corner radius. We stock more than 100,000 tools!
Premium tooling and technology for high-quality, precision machining.
Loading the player ...
